NAT exemption and Policy NAT
Feb 11th, 2009
Hi All,
I have the following NAT exemption configured on my firewall
access-list in_nat0_out extended permit ip 10.0.0.0 255.0.0.0 x.x.224.0 255.255.248.0
nat (inside) 0 access-list in_nat0_out
The statements above basically does the NAT exemption for us. Any 10.0.0.0/8 traffic from inside destined to the x.x.224.0/21 (this is our DMZ subnet), we do not perform NAT.
But now, we have a single device in the DMZ (IP is x.x.224.29) that we want to do NAT. Any 10-net traffic destined for x.x.224.29/32, I want to allocate a dynamic NAT pool.
The way I understand is, once I have nat 0 (or NAT exemption) configured, I cannot do a NAT on an overlapping network or address.
Is that correct? Or is it possible to do a NAT just for 1 address and nat 0 for all other addresses?
thanks,
Meena
eddie.mitchell@... Wed, 02/11/2009 - 06:34
  • Silver, 250 points or more
Have you tried the following?
access-list in_nat1_out extended permit ip 10.0.0.0 255.0.0.0 host x.x.224.29
nat (inside) 1 access-list in_nat1_out
global (dmz) 1 x.x.x.x-x.x.x.x netmask 255.x.x.x
Hope this helps.
mchockalingam Wed, 02/11/2009 - 06:43
No, I have not tried it yet.
I thought this will not work because my nat 0 command already has that address in it. x.x.224.29/32 is part of x.x.224.0/21 and it would take the first match which is my NAT exemption.
Does it look for a closer match or the first match?
Meena
mchockalingam Wed, 02/11/2009 - 17:04
Thank you Jon!
I was able to verify that NAT exemption takes precedence. The only way I can do policy NAT is if I exclude that address from the NAT exemption.
Thank you again!
Jon Marshall Wed, 02/11/2009 - 17:30
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Meena
No problem, glad to have been of help :-)
Jon
