Get UDPs uuid (pkid) into an array in PERL
Feb 11th, 2009
Hi all,
I'm new here, and also new in AXL.
Just trying to solve one case, where I need to copy value of user device profile description to line description on first line.
For one profile it's quite easy via this part of PERL script:
my $var2 = SOAP::Data->type('string')->name('profileName' => '...profile name...'); # specify profile name...
my $som2 = $soap->getDeviceProfile($var2); # and put into GetDeviceProfile
my $profileUuid = $som2->dataof("//getDeviceProfileResponse/return/profile/")->attr->{uuid}; # retrieve UDP uuid from getDeviceProfileResponse XML structure
my $dirnUuid = $som2->dataof("//dirn")->attr->{uuid}; # retrieve first line uuid
my $udpDesc = $som2->valueof('//description'); # retrieve value of UDP description (needed to copy to line description)
my @update3 = (
SOAP::Data->type('string')->name('uuid' => $dirnUuid),
SOAP::Data->type('string')->name('description' => $udpDesc));
my $som4 = $soap->updateLine(@update3);
But how to get in bulk?
My idea is to get device profiles uuid (pkid), add it to an array, after that make a cycle, where to every row will be assigned first directory number (dirn) uuid and from that make update line description.
I don't know, how to put all uuid's (pkid's) into an array, because sql query returns all at once.
my $sql = SOAP::Data->type('string')->name('sql' => 'SELECT pkid from Device');
my $arr = $soap->executeSQLQuery($sql);
Any idea?
Thanks in advance
Lukas Pecenka
