API data discrepancy
Feb 11th, 2009
When doing an api dump of data for several 2950 devices, it shows the number of ports defined on a device. The number of ports that have an associated IfIndex is 0. Why would a physical port not have an associated IfIndex?
Joe Clarke Wed, 02/11/2009 - 09:07
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Please post some sample data as well as the command you're running to get the data.
sirbaughmf Wed, 02/11/2009 - 11:46
Here is the command:
cwcli export inventory -u XXX -p XXX -view ""[email protected] - All Devices
Here is a sample of the output, notice that PortNumber 5 and 6 have Cisco_Port entries have a IfInstanceID after that there are no IfInstanceID's until PortNumber 15.
cevModuleCat3750Ge12Sfp
WS-C3750G-12S - Fixed Module 0
13
cevPortUnknown
InstanceName>StackPort1
cevPortBaseTEther
GigabitEthernet1/0/1
10101
6
cevPortBaseTEther
GigabitEthernet1/0/2
10102
7
cevPortGigBaseSX
GigabitEthernet1/0/3
8
cevPortGigBaseSX
GigabitEthernet1/0/4
9
cevPortBaseTEther
GigabitEthernet1/0/5
cevPortBaseTEther
GigabitEthernet1/0/6
11
cevPortGigBaseSX
GigabitEthernet1/0/7
12
cevPortGigBaseSX
GigabitEthernet1/0/8
13
cevPortGigBaseSX
GigabitEthernet1/0/9
14
cevPortBaseTEther
GigabitEthernet1/0/10
15
cevPortBaseTEther
GigabitEthernet1/0/11
10111
16
cevPortGigBaseSX
GigabitEthernet1/0/12
Joe Clarke Wed, 02/11/2009 - 11:59
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
I can't reproduce. What does the Detailed Device Report look like for this switch?
Joe Clarke Wed, 02/11/2009 - 12:18
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
If you run the cwcli output for this one device alone, do the results contain all of the IfInstanceIDs?
Joe Clarke Wed, 02/11/2009 - 12:40
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
I don't see any problems, and since I believe you're running RME 4.0.6, all known data discrepancy bugs of this nature should be fixed. I recommend you open a TAC service request so some database analysis can be done.
