02-11-2009 06:51 AM
Dear Mister
I have the next configuration:
rserver host WWW-GEMINIS
ip address 10.100.5.26
probe PING
probe HTTP
inservice
rserver host WWW-NOVA
ip address 10.100.5.5
probe PING
probe HTTP
inservice
serverfarm host WWW
rserver WWW-GEMINIS
backup-rserver WWW-NOVA
inservice
rserver WWW-NOVA
inservice standby
The ides is that when the WWW-GEMINIS is down, jump to the server WWW-NOVA. This is functioning. The problem is in when WWW-GEMINIS come back to up, WWW-NOVA still is receiving connections. WWW-NOVA remains in balancing, but the ral state is standby??
Which is my error???
Does exist another solutions???
Best Regards
02-11-2009 07:34 AM
Are you using stickyness?
That would be the only reason it still receives connections, because for me the config looks good.
02-11-2009 08:25 AM
Yes, iam looking the rest of configuration.
I must to disable that ???
Plly disable the policy regarding stick ???
Best regards and lot of thanks.
02-11-2009 08:44 AM
If you don't need the stickiness for any other reason and if NOVA is really just a backup for GEMINIS You could define two serverfarms with one rserver in each.
serverfarm host WWW-Primary
rserver WWW-GEMINIS
inservice
serverfarm host WWW-Backup
rserver WWW-NOVA
inservice
With only one server in each farm you don't need stickiness and then your loadbalance policy can look like:
policy-map type loadbalance first-match LB-POLICY
class class-default
serverfarm WWW-Primary backup WWW-Backup
Cathy
