Web VPN on 5540 ASA errors
ericmwangi
Hi guys,
I am setting up a web vpn on Cisco ASA 5540, however when i run webvpn enable outside command i get the following errors which i have attached. i am using version 8.0(4).
ericmwangi
BTW,
The VPN does work. Problem is that there is no title page and i canot modify the portal page nor restrict user access to the resources on the LAN. Not even after setting group policies. Once on the web VPN everything is accessible which should not be the case.
Eric
