MeetingPlace express VT cannot connect to Web Conferences
Feb 11th, 2009
I have MeetingPlace VT 2.0.3.35 and cupc clients (7.0.1)
All users pass the browser test, can ping the MPX NICS by hostname using MPX DNS entries - the NIC bindings are configured as per the best practices docs.
Clients have flash 9 and 10 installed.
I can start audio and video conferences without issue but clients cannot connect to web conferences.
I have tried initiating conferences directly from CUPC and from the MeetingPlace webadmin, both fail.
The browser attempts to connect, as I can see the green progress bar, until it eventually times out.
Eventually I get a Systen Error screen stating that the browser could not connect to the MPX server, please re-launch.
The address bar also has an error at the end of the URL ?launcher=false.
I have 6 web licenses available on the system.
srinivas_kr Wed, 02/18/2009 - 15:29
Hi Jonatha,
I had the same issue while connecting to meeting place with flash 10.Either you need to apply a hot fix as per the TAC support. Or else you need to uninstall flash 10 and install flash 9 to attend meetings
jonathan.magee Wed, 02/18/2009 - 15:44
Thankyou for the update, do you know the hotfix number is it an engineering special
srinivas_kr Mon, 02/23/2009 - 15:09
You can try this hot fix which I am enclosing and read the procured document. But I think you can use it only for Meeting place 6.0. Even then take a look.
Srinivas
