copy flash config
Answered Question
Feb 11th, 2009
I know there is a command in the recent IOS that allows you to copy a past config and have it over-write the current config.
Does anyone know what that is?
copy flash:my_config run - will only copy contents and they will be merged, but what is the command to copy and over-write fully without merging?
Correct Answer by John Blakley about 8 years 2 months ago
config replace flash:config run
HTH,
John
Overall Rating: 5 (1 ratings)
Correct Answer
John Blakley Wed, 02/11/2009 - 08:35
  • Purple, 4500 points or more
HTH,
John
