Cisco 7920 IP phone series and authentication with Access Point
Feb 11th, 2009
Hi All,
I am experiencing the problem when 7920 phone tries to authenticatw with enabled password access point. Actually, it gives authentication failed. And the interesting thing, If I configure AP to have open access ("no pwd"), then it works. Please advise. Thanks
montaser.shaer Sun, 02/15/2009 - 13:57
It is sloved.
I follow those config parameters:-
-authenication with ap:akm
-use wpa key (hexa,in my case, I use Alpha numeric)
- give static network config (Ip, tftp,...)
Remember of course to do apply changes option, for you changes to take effect.
After that, it should work.
Please let me know if you had any comment. Thx
