Syslog Reports - Resource Manager Essentials 4.1.1
Hi there,
When running a 24hr syslog report for an ASA5520 I get the following message -
"Warning SLCA0131: There are more than 10000 records generated for this date range.
Only 10000 records are being displayed, starting with the records generated on the end date.
To view the complete report, schedule a job that does not have Immediate as the Run Type"
After getting the warning I then schedule the report to run at a certain time. The report job seems to run ok but when checking the results I get the follwoing error message -
"SLCA0155: You cannot view the report
since the corresponding archive is already deleted or not available."
Any ideas?
Joe Clarke Wed, 02/11/2009 - 09:24
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Do you see the report listed under RME > Reports > Report Archives?
brentsullivan Wed, 02/11/2009 - 10:39
PIX 515
an outside client has source NAT(outside)0 x.x.x.x x.x.x.x
and the destination translated with a static
statice (inside, outside) x.x.x.x y.y.y.y
this client initiates atcp session and if the client serveris rebooted or the client looses connectivity for some reason, the translation is not ended. I need to enterthe command clear xlate for that translation. If I PAT'ed toasingle address I could expect multiple sessions but actually I wondered how to put a time out on the translation
Joe Clarke Wed, 02/11/2009 - 10:41
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You need to start a new thread in Security > Firewalling forum for this issue.
Joe Clarke Wed, 02/11/2009 - 11:40
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Please post the cri.log and the job log (found under NMSROOT\files\rme\jobs\syslog on Windows and /var/adm/CSCOpx/files/rme/jobs/syslog on Solaris).
Joe Clarke Thu, 02/12/2009 - 08:24
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
This is what I thought. Edit NMSROOT/WEB-INF/classes/com/cisco/nm/rmeng/inventory/reports/datagenerators/IRConfig.properties, and change MAX_HEAP_SIZE to 1024. Reschedule your job, and see if it works.
Joe Clarke Thu, 02/12/2009 - 10:41
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
My fault, some of the directories got truncated:
NMSROOT/MDC/tomcat/webapps/rme/WEB-INF/classes/com/cisco/nm/rmeng/inventory/reports/datagenerators/IRConfig.properties
Joe Clarke Thu, 02/12/2009 - 11:18
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Please post the new cri.log.
[Edit]
Nevermind, I checked, and the syslog reporting jobs are not using the dynamic memory config. They are hardcoded to 256 MB as a maximum. Go ahead, and open a TAC service request. I can provide a patch for this.
