Caller id name on a PSTN call
Answered Question
Feb 11th, 2009
Does anybody knows if I can configure a callmanager 4.1 to display an special caller id name when I receive a PSTN call?
Correct Answer by paolo bevilacqua about 8 years 4 months ago
Yes. Check anyway that QSIG is not mandatory for calling name, PBX could be using display Information Element.
Overall Rating: 5 (1 ratings)
paolo bevilacqua Wed, 02/11/2009 - 13:51
  • Hall of Fame,
    Founding Member
If you use H.323, you could use a TCL/IVR script that I wrote:
http://pbevila.fastmail.fm/public/
number2name, there are two varieties, one has HTTP query support, the other a more robust logic, I shall reunify them someday.
fcovallem Wed, 02/11/2009 - 14:13
Hi Paolo,
Thanks for your response.
My case is this: My customer is using an Ericcsson PBX and a CallManager but the Ericcsson does not have suplementary QSIG support and does not send the name asociated with the caller id.
My customer is asking if we can do something to match de CLID that we receive with the name asociated with this number to display it on the ip phones.
According to this, the TCL script works?
Thanks again
Correct Answer
paolo bevilacqua Wed, 02/11/2009 - 14:15
  • Hall of Fame,
    Founding Member
