PEAP with RSA question
Feb 11th, 2009
I am getting ready to install a wireless network with WLC4404, ACSSE and about 100 AP's. The current network is a Novel network and every user has an RSA token. We want to be able to have the users use their RSA token with connecting to the wireless.
I have found all the documents from here on how to configure ACS including getting the certificate and adding in the RSA server. I also know how to add the information to the RSA server for the ACS.
What I am not sure about is the setup of the windows XP SP2 machine for RSA security.
From what I have read, it seems that I just need to select WPA2, AES, then select PEAP, and under PEAP options choose Smart Card. Is this all?
When I looked at the RSA sites documents, their screen shots show the ability to choose a hardware or software token.
Seth
srosenthal Mon, 02/16/2009 - 19:46
I have been doing some research into this.
If I have this correct, I cannot use the RSA token directly with Window's without using a supplicant like Funk Odyssey or Cisco.
Is this correct?
Seth
Trending Topics - Security & Network
