Aaron Harrison Fri, 02/13/2009 - 09:20
  • Community Spotlight Award,
    Member's Choice, May 2015
It sounds like you may be inserting 'all details' instead of 'specific details'?
'all details' should be picked when you are using a CSV generated from CCM.
If you are using the BAT spreadsheet, you would normally use 'specific details' for things like phones. You'd then pick a template that you had defined with default properties in it, and merge it with your uploaded file.
Aaron
Please rate helpful posts...
