group-lock for vpn users with acs
fredj1234
Is there any way to controll what VPN profile a user is allowed to use through Cisco ACS, or the router?
Using 2811 router IOS ver 12.4, ACS 4.1
I just want to be sure that the VPN user can only use the Client Profile assigned to them and no other Group Profiles.
Example:
User123abc gets their hands on a co-wokers profile.
HR_User_Profile.pcf
SALES_User_Profile.pcf
User123abc belongs to HR department and should only be able to authenticate with HR_User_Profile. If User123abc tries to authenticate using the SALES_User_Profile access should be denied.
Any documentation explaining how to set this up?
The ASA will be your option. This has to be controlled by the group-policy, group-lock, tunnel-group and class values on ACS and ASA
Ivan Martinon
Level 7
Level 7
Unfortunately the only kind of group lock that routers support is with local authentication. Having an ACS will not be a viable solution since the router will not understand the class attribute sent back from the ACS (if any). You will find out that the router has the option of group-lock but this will only work when the user is stored on the router DB.
Thank you for your reply.
Is it possible to acheive this with a Cisco ASA5510 or does this device have the same limitation as the router?
Are there any other scalable Cisco solutions for this?
(just guessing like changing to a PKI authentication or something else??)
I also found this doc, but do not plan to use VPN concentrator because its EOL.
http://www.cisco.com/en/US/customer/tech/tk59/technologies_configuration_example09186a00800946a2.shtml
Thanks.
ansalaza
Have you tried sending this "ipsec:user-vpn-group=XXXXXX" in cisco-av-pair?
This command was introduced. 12.2(13)T
If RADIUS is used for user authentication, then use the User-VPN-Group attribute instead of the Group-Lock attribute.
ipsec:group-lock=1
Group-lock
http://www.cisco.com/en/US/docs/ios/12_3t/secur/command/reference/sec_i1gt.html#wp1182957
The User-VPN-Group attribute is a replacement for the Group-Lock attribute...
If you need to check that the group a user is attempting to connect to is indeed the group the user belongs to, use the User-VPN-Group attribute. The administrator sets this attribute to a string, which is the group that the user belongs to. The group the user belongs to is matched against the VPN group as defined by group name (ID_KEY_ID) for preshared keys or by the OU field of a certificate. If the groups do not match, the client connection is terminated.
ipsec:user-vpn-group=cisco
User-VPN-Group
http://www.cisco.com/en/US/docs/ios/security/configuration/guide/sec_easy_vpn_srvr_ps6350_TSD_Products_Configuration_Guide_Chapter.html#wp1097654
