ASA5520 config nat but also can not access inside webserver from outside
Feb 11th, 2009
Webserver Real Inside address:
Webserver static translation address: 999.25.160.166.
I can ping 999.25.160.166 from Internet and remote desktop access server 999.25.160.166 with port 3389 .
But I can not web access server 999.25.160.166, and I am sure web service in 999.25.160.166 is ok , i can web access server inside .
My configuration :
ASA Version 7.2(4)
interface GigabitEthernet0/0
nameif outside
security-level 0
ip address 999.25.160.165
interface GigabitEthernet0/1
nameif inside
security-level 100
ip address
boot system disk0:/asa724--k8.bin
boot system disk0:/asa722-k8.bin
ftp mode passive
access-list inside_access_in extended permit ip host any
access-list outside_access_in extended permit tcp any interface outside eq 3389
access-list outside_access_in extended permit tcp any interface outside eq telnet
access-list outside_access_in extended permit tcp any host 999.25.160.164 eq 81
access-list outside_access_in extended permit ip any host 999.25.160.166
pager lines 24
logging enable
logging asdm debugging
mtu outside 1500
mtu inside 1500
ip local pool vpnpool mask
no failover
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-522.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1
static (inside,outside) tcp interface 3389 3389 netmask
static (inside,outside) tcp 999.25.160.164 81 81 netmask
static (inside,outside) tcp interface telnet telnet netmask
static (inside,outside) 999.25.160.166 netmask
access-group outside_access_in in interface outside
access-group inside_access_in in interface inside
route outside 999.25.160.161 1
route inside 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
aaa authentication ssh console LOCAL
http server enable
http outside
http inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
telnet inside
telnet timeout 5
ssh outside
ssh inside
ssh timeout 5
console timeout 0
class-map inspection_default
match default-inspection-traffic
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect netbios
inspect rsh
inspect rtsp
inspect skinny
inspect esmtp
inspect sqlnet
inspect sunrpc
inspect tftp
inspect sip
inspect xdmcp
inspect icmp
service-policy global_policy global
prompt hostname context
: end
Thanks for Any suggestion.
Jithesh K Joy Wed, 02/11/2009 - 19:57
Your NAting& access-list are good.
Please add http inspection to the policy-map global_policy.
inspect http
