Sticky with cookie
Answered Question
Feb 11th, 2009
Do you know how to configure 11501 to have sticky with cookie while SSL is used.
Thanks.
Correct Answer by Syed Iftekhar Ahmed about 8 years 2 months ago
No You cannot.
As I said earlier traffic that will pass through CSS will be encrypted. Css wont be able to open header and read cookie.
Your only option is to use IP address based stickiness.
Syed Iftekhar Ahmed
Overall Rating: 5 (2 ratings)
Syed Iftekhar Ahmed Wed, 02/11/2009 - 18:55
  • Blue, 1500 points or more
Are you offloading SSL on CSS?
If not then CSS cant look into the header and you cannot use cookie as sticky.
Syed Iftekhar Ahmed
josephschung Wed, 02/11/2009 - 19:01
SSL is NOT terminated on 11501, the cert is install on web servers behind CSS. Can use cookie as sticky?
Thanks.
Correct Answer
Syed Iftekhar Ahmed Wed, 02/11/2009 - 19:44
No You cannot.
Syed Iftekhar Ahmed
jgurfinkiel Thu, 02/12/2009 - 08:55
If SSL is terminated on the server, either you so stickuness based on SSL ID, or on Source IP, or Source IP/dest. port because you cannot read the cookie within the SSL (encrypted) traffic
Hope this helps
Syed Iftekhar Ahmed Thu, 02/12/2009 - 12:23
I am not an advocate of SSL ID based stickiness.
It should be kept in mind that using SSL ID (as a sticky method) is not a very reliable method (because of
SSL renegotiation by some clients).
For example some IE versions renegotiate the SSL-id during a session. This forces a new
session-id so sticky is no longer there.
Source IP is more reliable unless larger number of clients are using same Source IP address ( Using a Mega proxy server ).
Following link will give you some idea about ssl-id renegotiation.
http://support.microsoft.com/kb/265369
Syed Iftekhar Ahmed
josephschung Fri, 02/13/2009 - 01:17
Thanks Syed.
Below is my existing configuration:
content SSL
vip address 10.106.13.224
redundant-index 36
advanced-balance ssl
application ssl
add service WEB01
add service WEB02
protocol tcp
port 443
url "/*"
active
Do you recommend to replace the following with "advancedbalance
sticky-srcip"?
application ssl
port 443
Thanks.
Syed Iftekhar Ahmed Fri, 02/13/2009 - 02:07
If you are running this config without any complains then you dont need to change it.
SSL ID renegotiation problem is with limited number of browsers. If you are not receiving any complains then you are good.
Syed Iftekhar Ahmed
josephschung Sat, 02/14/2009 - 07:47
The application team complain that there time out counter of 30min does not seems working very well.
Maybe it worth a try to replace the commands.
