Extension Mobility Hang
Feb 11th, 2009
I have experienced a hang on the extension mobility service. I configured it correctly and can login and logout. I experience a hang on logging in and out more often than being successful. Is it possible that this concerns low memory resource of the CallManager? Can I just add additional 2GB memory on the 7825I CallManager Server to increase the memory and will this solve the issue? Thanks in Advance =)
irisrios Wed, 02/18/2009 - 13:12
  • Silver, 250 points or more
Yes, by increasing the memory it might solve your problem. It looks like you're running on the min. amount of memory required.
nprdomingo Wed, 02/18/2009 - 16:43
Thanks for the reply Iris.
Is it also possible that it is a known bug to Cisco CallManager 6.0?
We raised this to TAC and they said it is a known bug so we are also considering it. If it is a known bug, it should have been fixed before for we are already running the latest version.
