Time Out Error
Feb 11th, 2009
I have my script setup so When the welcome prompt times out it repeats the prompt for 3 times. the problem is that the first time only before the audio file plays again, it says are you still there.after that it goes trough the prompt 2 times without saying that again. Any suggestion? Thanks in advance.
Anthony Holloway Thu, 02/12/2009 - 09:22
  • Purple, 4500 points or more
I believe you can overwrite all of the system prompts, however I would not suggest that.
One quick solution is to control the timeouts yourself.
create an int variable, and a label, then count the loops.
Set menuCounter = 0
:PlayMainMenu
Menu (This menu has a retry count of 0)
-- Option 1
---- Do something
-- Option 2
---- Do something
-- Timeout
---- +increment menuCounter
---- if menuCounter < 3
------ Goto PlayMainMenu
---- else
------ Goto handleTimeout
