02-11-2009 10:28 PM
Does waas support cisco conf copy mib. Basically requirement is to run configuration backup daily.
Srinath M
02-12-2009 06:19 AM
Srinath,
WAAS Supports the following mibs (maybe you can reference what's available from the CISCO-CONFIG-MAN-MIB?):
â¢ACTONA-ACTASTOR-MIB
â¢CISCO-CDP-MIB
â¢CISCO-CONFIG-MAN-MIB
â¢CISCO-CONTENT-ENGINE-MIB
â¢CISCO-ENTITY-ASSET-MIB
â¢CISCO-SMI
â¢CISCO-TC
â¢ENTITY-MIB
â¢EVENT-MIB
â¢HOST-RESOURCES-MIB
â¢MIB-II
â¢SNMP-COMMUNITY-MIB
â¢SNMP-FRAMEWORK-MIB
â¢SNMP-NOTIFICATION-MIB
â¢SNMP-TARGET-MIB
â¢SNMP-USM-MIB
â¢SNMPV2-MIB
â¢SNMP-VACM-MIB
They are documented in the following link - http://www.cisco.com/en/US/docs/app_ntwk_services/waas/waas/v411/configuration/guide/SNMP.html#wp1107077
Dan
02-12-2009 06:25 AM
Hi Dan,
Thanks for the input. I was trying to copy the running configuration of WAE to a TFTP server for daily backups. It was not responding for CISCO-CONFIG-COPY MIB, i will check for the CISCO-CONFIG-MAN-MIB and will update this forum with the results.
Thanks again.
Sri
