Boot a MFSC on 6509
patrickmignon
I received a Cisco Spare SUP1A-2GE without MFSC board. I reinstall the MFSC + DRAM +BootFlash to the new board. And copy all files on the PCMCIA (slot0: ) from my backup SUP1. The copy checksum + lenght are good and the same.
When I load the MFSC file in "rommon" mode from the slot0: the file is decompressed then the CATOS is loaded. When I received the CAT prompt I type the show module and the module is not loaded. I have tryed with another mfsc file it is the same.
Have you an idea how can I load the MFSC?
Thanks Patrick
Giuseppe Larosa
Hello Patrick,
for HW installation see
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/hardware/Config_Notes/78_10605.html#wp30615
then there are procedures to trobleshoot booting issues here
http://www.cisco.com/en/US/products/hw/switches/ps700/products_tech_note09186a008013495f.shtml#read_bootfile_fail
see the section
Unable to Read the External Flash Card from MSFC2
Hope to help
Giuseppe
Hi Giuseppe,
Thank you for the quick help!
But strange when I type the command from rommon > boot slot0: c6msfc2-boot-mz.121-13.E15.bin
the file is uncompressed.
and if the file is unreadable I receive an error message.
I need to place a space carracter after slot0: otherwize it gives me an checksum error !
And it can load the CAT OS file from the Flash!
I will try to load a new MFSC2 file tomorrow!
Best Regards
Patrick
