7906 routet
Feb 12th, 2009
i have a 7609 router with this ios s72033-adventerprisek9_wan-mz.122-18.SXF15a.bin but i can not cofigure the communication media module card on it,when i do (card type ? )it gives me error, when i do controller E1 or T1 ? it's still give me error can anyone help.
Overall Rating: 5 (1 ratings)
Edison Ortiz Thu, 02/12/2009 - 06:32
What type of module do you have? SIP/SPA or FlexWAN?
Some of the modules requires SR code instead of SX code in the 7600.
SELOMECIS Thu, 02/12/2009 - 06:45
here is the module (WS-SVC-CMM-6E1) and the IOS VERSION IS (
Version 12.2(18)SXF15a, RELEASE SOFTWARE (fc1) ANY HELL
SELOMECIS Fri, 02/13/2009 - 08:36
Thanks u very much for ur help now i configured the E1 and it's working but im still having one problem,any time i restarted the router it went to Rommon mode and i needto connet the consloe and boot with the ios on the disk.any help
Jerry Ye Fri, 02/13/2009 - 08:44
Just want to understand which module is going into ROMMON? You should check the config-reg value, for a normal IOS for 7600/6500 or CMM, it should be set to 0x2102. You can verify it by using show version .
To change it:
conf t
config-register 0x2102
SELOMECIS Fri, 02/13/2009 - 08:48
the config-register is 02102,but i dont know why is going to rommon mode,the 2 modules always go to rommon mode when i restart the router.
SELOMECIS Mon, 02/16/2009 - 01:35
I find the solution,the problem was the IOS is on the flash disk i slot in the router and i did not point the boot system flash tothe disk that's why,thanks very i enjoy usint this discussion forum.
