WLC - Domain name configuration....
Feb 12th, 2009
hi All,
I am trying to configure the domain name in wlc but i am not geeting the option.
If i checked the sh cdp nei on switch where my LWAPP connected....its showing...
puna-wpi-ap-1g.cisco.com....
where i think cisco.com is default domain.
So pls give me the appropriate solution to configure the domain in WLC.
Waiting for the reply ASAP.....
Thanks & Regards,
RAJU
jeff.kish Thu, 02/12/2009 - 07:45
  • Silver, 250 points or more
What version code are you running? I seem to recall that in early versions of code this cannot be changed.
jeff.kish Fri, 02/13/2009 - 07:16
I think you need to be on 5.0+ to modify the domain name.
Can anyone else confirm that?
Stephen Rodriguez Mon, 02/16/2009 - 14:46
  • Purple, 4500 points or more
4.2 shouldn't have had an issue with the domain name, I believe that started in 5.0, and was fixed in 5.2. If the AP is getting DHCP, then the domain name should be set from the DHCP option. If you are using static, you would need to use a command to gain access to the CLI of the AP to set it, but it will not persist through a rebot as you cannot write to the memory of an LWAPP AP.
HTH,
Steve
