Copy Image, get "out of sequence" errors
Feb 12th, 2009
During the TFTP copy of an IOS image to a 6509 switch, the copy started going fine, then started getting out of sequence indicators.
The IOS finished copying, and I see the image on the disk, but I am wondering, should I be concerned about that image?
Or no?
Overall Rating: 5 (3 ratings)
Edison Ortiz Thu, 02/12/2009 - 06:06
The verify command is very useful when it comes to that.
If you run it against the image you downloaded, it will report the MD5 value.
You can compare the MD5 value reported to you to the one from the download page, if they match - the image was copied properly.
It should also report if the image is invalid.
wilson_1234_2 Thu, 02/12/2009 - 08:47
I am getting something totally different on the "Verify"
Embedded Hash MD5 : BC422FEA4472CB24398B9C361602FAC8
Computed Hash MD5 : BC422FEA4472CB24398B9C361602FAC8
Signature Verified
LKLD-6509-RTR-1#dir disk1:
Directory of disk1:/
and what is shown in the Detail MD5 on the download page
MD5 e1da279d7a59e1278ecdd763d10afd6c
Edison Ortiz Thu, 02/12/2009 - 09:04
What's the image name?
That's odd - I have a 6509 with SXF8 and it matched CCO
Embedded Hash MD5 : DA2654E6FCDF4556B065637ABECF33D3
Computed Hash MD5 : DA2654E6FCDF4556B065637ABECF33D3
CCO Hash MD5 : 21FC4B0D8FE650D93C88791EF8F5DFD8
Signature Verified
From CCO:
Release 12.2.18-SXF8
Size 82558532
BSD Checksum -
Router Checksum 0xc964
MD5 21fc4b0d8fe650d93c88791ef8f5dfd8
Date Published: 13-DEC-2007
Once we verify the image you selected from CCO is the same as the one you have, then we can conclude the image is good or not.
wilson_1234_2 Thu, 02/12/2009 - 11:07
Sorry Edison,
I was a bone head:
MD5 from download page:
Leo Laohoo Thu, 02/12/2009 - 14:16
Don't worry about this. The "O" is a sign of low latency. What matters are the "Ok!" and the Transfer Complete at the end of the process. I see this all the time when I transfer IOS via the low-speed WAN & satellite link.
