TACACS+ / SSHauth
Feb 12th, 2009
I have an Cisco MDS environment with tacacs+ user authentication.
Now I would like to script some stuff and automatically login to the switch via ssh without a password.
How can I do that with TACACS+?
Is it still possible to use private/public sshkeys? If yes - how does this work with cisco switch? (Where do I put key from my host?)
thanks for help
rgds,
Mike
inch Thu, 02/12/2009 - 12:31
  • Bronze, 100 points or more
Hi Mike,
You can use ssh keys on MDS'. From the top of my head (its been a while!) its
config# username blah sshkey your_key_here
or something similar, like I said its been a while.
Cheers
Mike_Lowrey Fri, 02/13/2009 - 10:22
thanks - it works with key.
However I still would like to store this sshkey on a central place.
If I do it the"normal" way I need to create a local user on every switch and assign a key to this user. I would rather use my tacacs+-server for that. E.g. assign the pub key in the tacacs config file to a user instaed of a passord. Is this not possible?
rgds,
Mike
Michael Brown Fri, 02/13/2009 - 14:14
  • Cisco Employee,
I would have to defer to a TACACS+ expert on that. The only way I know that is has ever been done, is with the keys. If you want to use the TACACS+ server, as far as I know, you would need to use password authentication for the SSH login.
Mike
Trending Topics: Storage Networking
