02-12-2009 06:01 AM - edited 03-04-2019 03:32 AM
Dear,
We have router which is up since 2 days and I would like to know if the router has reloaded by CLI (Reload) or by power off(Electrical problem)
ROM: System Bootstrap, Version 12.4(12.2r)T, RELEASE SOFTWARE (fc1)
BOOTLDR: Cisco IOS Software, 7200 Software (C7200P-KBOOT-M), Version 12.4(4)XD9, RELEASE SOFTWARE (fc1)
Router-Test-01 uptime is 2 days, 21 hours, 0 minutes
System returned to ROM by reload at 16:54:56 UTC Mon Feb 9 2009
System restarted at 16:56:23 UTC Mon Feb 9 2009
Last reload reason: Reload Command
Last reset from power-on
1 FastEthernet interface
4 Gigabit Ethernet interfaces
2045K bytes of NVRAM.
02-12-2009 06:03 AM
it was manuall reloaded from the cli.
02-12-2009 06:28 AM
How you can say it?
02-12-2009 06:32 AM
This statement indicates it...
Last reload reason: Reload Command.
If it helps, please rate post..
02-12-2009 06:33 AM
Thanks, I rate it
02-12-2009 06:35 AM
Because the output says
"System returned to ROM by reload at 16:54:56 UTC Mon Feb 9 2009"
If it was a power problem it would have said something like
"System returned to ROM by unknown reload cause"
02-12-2009 02:01 PM
They're all right. The second and the last line always gives you a clue.
If it's a power outage, the line would go something like "System returned to ROM by power-on".
If there was something wrong, in this case a system crash, you'd get an alarm like this:
System returned to ROM by error - Software Forced Crash Exception (0x0700)!, PC 0x3ED134
System restarted at 05:10:29 AEDST Tue Nov 18 2008
If it was reloaded, you still get this
System returned to ROM by reload at 15:55:01 AEDST Fri Feb 6 2009
Does this help?
