02-12-2009 06:02 AM - edited 03-15-2019 04:10 PM
Hi, I am trying to upgrade from ccm 6 to 7. I put the ccm DVD 'upgrade from 6 to 7' in the DVD drive..
I then go to os administration page software upgrades and choose 'dvd/cd option. In the directory field, I put a / or a \ and when i click next i get the following error
"upgrade candidates found in patch directory are not allowed by the curren version"
Has anyone come across this error before? HAs anyone upgraded from 6 to 7 and had similar problems..
Derek
02-12-2009 06:30 AM
Hi Derek,
You are not going to like this answer, but, you cannot upgrade from CUCM 6.1(3)to CUCM 7.x at this point in time. Cisco should put this type of note in HUGE RED letters;
Release Notes for Cisco Unified Communications Manager Release 6.1(3)
Updated January 6, 2009
Caution: Be aware that you can not upgrade directly from Unified CM 6.1(3) to Unified CM 7.0
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/rel_notes/6_1_3/cucm-rel_note-613.html#wp433777
Table 4;
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr.html#wp40074
Hope this helps! Sorry my friend,
Rob
02-12-2009 07:47 AM
Hi Rob,
Thanks for the update
Can I revert back to 612 sr1002(this is on my inactive Partition) and upgrade direct from there?
If so, will i lose all my configuration?
Derek
02-12-2009 09:11 AM
Hi Derek,
I would truly engage TAC on this one. I have seen a number of posts where people ran into issues with this "downgrade" process prior to the CUCM 7.x upgrade :)
Rob
02-12-2009 09:19 AM
thanks Rob.. I have a call in with Cisco
02-12-2009 09:40 AM
Hi Derek,
You are most welcome my friend! Let us know how you make out with this.
Best of luck,
Rob
