Error: Unity CN7 integration with CallManager 7
Feb 12th, 2009
Hi all, I am having the following error when integration the Unity CN7 with CCM7. The voicemail port failed to register with CCM7. I am doing the integration using SCCP.
Failure reason: ErrorReceivedSkinnyRegisterRejectMessage. SCCP message = [StationRegisterRejectMessage (36 bytes) text=""]
Thanks.
boonchin.ng Thu, 02/12/2009 - 06:36
I have also double confirm that the "security mode" and "sccp device name" are matched on both CCM and Unity CN.
Thanks.
t.muhammad Tue, 07/28/2009 - 09:56
I'm having the same exact problem with this. Did you find a fix? Any help is appreciated. Callmanager 7.1.2 and Unity Connection 7.1.2
