erase bootvar
Feb 12th, 2009
friends,
look into the below info
BOOT variable = ,1;s3223-entservicesk9_wan-mz.122-18.SXF8.bin,1;bootdisk:s3223-e
ntservicesk9_wan-mz.122-18.SXF8.bin,1;bootdisk:s3223-entservicesk9_wan-mz.122-18
.SXF8.bin,1;
CONFIG_FILE variable =
BOOTLDR variable does not exist
what does this "BOOT variable = ,1" refer to, how to clear this boot var statement. i need to point it to single image followed by 1.
i want the output to be configured as
MSFC(boot)# show boot
BOOT variable = s3223-entservicesk9_wan-mz.122-18.SXF8.bin,1
CONFIG_FILE variable does not exist
BOOTLDR variable = bootflash:s3223-entservicesk9_wan-mz.122-18.SXF8.bin
kindly guide me
Overall Rating: 5 (2 ratings)
Yudong Wu Thu, 02/12/2009 - 09:02
  • Gold, 750 points or more
"BOOT variable = ,1" refer to command "boot system flash".
Type "sh run | i boot system" to see what boot statement in the current config. And then remove unused boot command. Then "wr mem" and check "show boot" again.
ullasupendran Thu, 02/12/2009 - 13:32
In your case remove the existing boot system commands and try the following one.
boot system flash:s3223-entservicesk9_wan-mz.122-18.SXF8.bin
boot system bootldr bootflash:s3223-entservicesk9_wan-mz.122-18.SXF8.bin
I assumed that the bootloader you mentioned in the output is correct.
Hope to help
Ullas
