SDSL vs bonded adsl
Feb 12th, 2009
Hi all, for business use, some vendors are offering bonded adsl and sdsl,
my questions are, If they say the sdsl is private, when it needs to talk to my other internet service, will it need a breakout from the providers private circuit to the internet?
also, ca you have point to point sdsl circuits, how would they do this ?
Giuseppe Larosa Fri, 02/13/2009 - 10:03
  • Hall of Fame,
    Founding Member
Hello Carl,
with SDSL you can build a point-to-point service like using two serial interfaces: they can be even connected back to back without going through a service provider infrastructure.
Actually SDSL can be used and it is used as an E1/T1 extender.
For this reasons they say SDSL can be seen as a private line as a form of leased line.
SDSL is able to have one side to behave as CPE (ATU-R) and one as CO (ATU-C) the service is symmetric and simply they need to change the frequencies to change behavior.
With ADSL you have asymmetric bandwidth and this point to point capability is not available and you need to use the provider data infrastructure because each ADSL link is terminated at CO on a ATU-R modem on the DSLAM.
Hope to help
Giuseppe
