Graphical QoS monitor?
Feb 12th, 2009
I've just deployed QoS on my internet edge and WAN routers and would like to monitor QoS and its behavior with a graphical system as opposed to logging onto each device. Is there a tool out there that can help with this? I know that Cicso once had a component of Ciscoworks that was used for deploying QoS - but I beleive it was expensive and is no logged avalible.
thanks for any input.
-calvin
Istvan_Rabai Thu, 02/12/2009 - 09:31
Hi Calvin,
Try Cisco SDM (Security Device Manager) for Windows.
It has a fairly simple graphical representation of traffic classes and queues and respective traffic loads.
You should be able to download SDM from the Cisco website if you have a suitable CCO account.
Cheers:
Istvan
