The command "show icmp" does not work on Cisco ASA
Feb 12th, 2009
In the Cisco ASA 8.0 Command Reference it says that "show icmp" can be used to display the ICMP configuration, but it is not available (at least not on our 5540s):
ciscoasa# show icmp
ERROR: % Invalid input detected at '^' marker.
ciscoasa#
We are running version 8.0(4) and 8.0(4)23. I am logging in with an account that has privilege level 15.
Does anyone know if this is a known bug?
Best regards,
Harry
JORGE RODRIGUEZ Thu, 02/12/2009 - 09:57
  • Green, 3000 points or more
You may also try bellow syntax to include icmp acls if any.
show run | inc icmp
net-harry Fri, 02/13/2009 - 00:52
I understand that I could use "show run icmp" or "show run | include icmp", but I was hoping that the command "show icmp" would give some information about the status of the icmp access lists.
For instance how many packets that hit the different imcp permits and denies. Today I only see the log entries for denied attempts, but it would be nice to see how many packets hit the filters.
Also, I think that either the command should be available or it should not be listed in the command reference...
Best regards,
Harry
Ivan Martinon Fri, 02/13/2009 - 07:52
  • Cisco Employee,
For instance there is not such command on the device:
ciscoasa# show icmp
ciscoasa# show i?
idb igmp interface ip
ipsec ipv6 isakmp
ciscoasa# show i
My guesses this docs where copied from the PIX 6.X docs and that is why it shows the command there, as you can see it shows it is a pre existing command.
About showing the hits on acls, the only way is with show access-list and defining a criteria like icmp, about the icmp configuration to the device and from the device your option is show run icmp
http://www.cisco.com/en/US/docs/security/asa/asa80/command/reference/s3.html#wp1427048
