ASDM ASA5505
Answered Question
Feb 12th, 2009
The ASA5505 was re-set to factory default configuration. Opened a browser with address https://192.168.1.1. A window pops asking for the username and password. What is the default username and password?
Thanks.
Correct Answer by thomasdzubin about 8 years 5 months ago
If it helps any, I had all sorts of ASDM login problems until I downgraded Java from v6 update 11 to v6 update 10
Overall Rating: 0 (3 ratings)
Ivan Martinon Thu, 02/12/2009 - 09:31
  • Cisco Employee,
since it is back to the default settings it should not have username and password, have you tried just hitting enter on this? if it does not work try a blank username and "pix" as a password.
saidfrh Thu, 02/12/2009 - 09:39
blank for username and password does not work,
blank username and cisco password does not work,
administrator username cisco does not work,
administrator username blank psswd does not work,
cisco cisco does not work either.
Ivan Martinon Thu, 02/12/2009 - 09:51
  • Cisco Employee,
try:
enable_15 for username and "cisco" or "pix" for password
saidfrh Thu, 02/12/2009 - 10:01
enable_15 for username and "cisco" or "asa", enter/blank for password do not work
tititech2007 Thu, 02/12/2009 - 10:08
Check your java version. I had the same problem.
Please install java JRE 6 update 7 and it will fix your problem.
Correct Answer
thomasdzubin Thu, 02/12/2009 - 10:43
saidfrh Thu, 02/12/2009 - 09:32
The following were inputed. A static IP for a computer of 192.168.1.2 has been assigned to configure the ASA.
asdm image flash:/asdm.bin
http server enable
http 192.168.1.2 255.255.255.255 inside
