How to telnet from CISCO ASA 5505
Feb 12th, 2009
I have a cisco asa 5505 that is setup as the ssh server. I am able to access it without any problem.
Once connected to the ASA 5505, I would like to telnet to my old terminal server 2509 that doesn't support ssh.
How to telnet a device FROM cisco asa 5505?
JORGE RODRIGUEZ Thu, 02/12/2009 - 10:03
  • Green, 3000 points or more
You cannot initiate telnet session from any ASA/PIX firewall, you will have to allow straigh telnet access from outside to inside towards the 2509 server.
tititech2007 Thu, 02/12/2009 - 10:12
Thanks -
That is what I am doing right now. But I don't feel secure accessing my home lab using telnet.
Is there a workaround for me to access the 2509 securely with asa?
Tshi M Thu, 02/12/2009 - 10:25
  • Silver, 250 points or more
I am assuming that you have a switch. How about ssh to the switch and from the switch telnet to the 2509?
tititech2007 Thu, 02/12/2009 - 10:33
Thanks - I am going to try it.
But, Is that possible to forward port 22 to a switch with cisco asa?
Tshi M Thu, 02/12/2009 - 10:38
I'd have to try it myself. But how about setting up a VPN session? It will be more secure.
tititech2007 Thu, 02/12/2009 - 12:03
Vpn traffics are block at my workplace.
I am able to vpn to my home lab from starbuxx but not at my workplace. Ssh and telnet are the only open ports i find so far.
I want to connect to my home lab from work because I have some free time that I would like to invest to get my CCNP certification.
Yudong Wu Thu, 02/12/2009 - 12:05
  • Gold, 750 points or more
If IPSec vpn is blocked. SSL vpn should work fine. refer to my post below.
JORGE RODRIGUEZ Thu, 02/12/2009 - 12:36
I agree with Keven's idea, I would be surprised SSL be block at your work place, if from your work you are allow internet banking most likely they allow ssl , so configure webvpn in your asa5505 and you can prety much access all your inside resources through webvpn.
tititech2007 Fri, 02/13/2009 - 15:58
Thanks -
I am now able to webvpn to the asa but I can't figure out how to telnet from the webvpn to my terminal server.
I need some help -
tititech2007 Sat, 02/14/2009 - 12:27
Thanks for the new link - I am going to try it - I will let know about the result.
tititech2007 Wed, 02/18/2009 - 17:15
Thanks -
I am able to telnet to my old terminal server 2509 through webvpn.
I am going to post a video of the configuration step by step. I hope it will help other members of the community.
Thanks to all of you who has help me- I will make you pround by passing the ccnp cert this year.
Yudong Wu Wed, 02/18/2009 - 20:48
Martial,
Thanks for sharing.
Good luck on your CCNP test.
