Command information :no dss interface-purge
Feb 12th, 2009
  • Silver, 250 points or more
I've got this in the default config of a new 6500 VSS. Can someone tell me what it is?
no dss range-purge
no dss mac-purge
dfedotovs Thu, 03/13/2014 - 05:25
Dominic,
Sorry to bump the old thread but your entry was the only one I've found.
I have observed that this set of commands is enabled after disabling Netflow on the 6500 switch PFC with "no mls netflow".
I wasn't able to find any information on these commands and impact of them. Did you have any luck with this?
Dmitri
