BGP network statement
Feb 12th, 2009
  • Purple, 4500 points or more
All,
If I have three interfaces:
int lo1
ip address 172.5.5.5 255.255.255.255
int fa0/0
int s1/0
ip address 10.5.5.1 255.255.255.252
Would my network statements in BGP for s1/0 and lo1 look like:
network 10.5.5.0 mask 255.255.255.252
network 172.5.5.5 mask 255.255.255.255
network 192.168.1.0 mask 255.255.255.0
In other words, my masks in bgp should match what's on my interface, right? I know there's exceptions to the rule.
Thanks!
John
Overall Rating: 5 (3 ratings)
Edison Ortiz Thu, 02/12/2009 - 10:18
  • Hall of Fame,
    Founding Member
Yes, it must match the mask in the routing table.
__
Edison.
Richard Burts Thu, 02/12/2009 - 10:20
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
John
When you use the mask in the BGP network statement then BGP looks into the routing table for a prefix with exactly that mask. So you your BGP mask should match what in on your interface.
Rick
Harold Ritter Thu, 02/12/2009 - 10:26
  • Cisco Employee,
John,
That is correct. By the way, the mask configured on the network statement for 192.168.1.0 is the default maks for a class C prefix and will therefore not show in the config.
