02-12-2009 10:39 AM
I get a JRM error message when trying to delete any job that does not show a completion time.
Error
Failed while deleting job(s)
Possible Cause: Could not delete job in JRM: 2432
Any ideas on what may be causing this error message
Server info:
Windows 2003 server r2 sp1
LMS 2.6
-CiscoWorks Common Services 3.0.6
-Resource manager Essentials 4.0.6
-Campus Manager 4.0.6
-CiscoView 6.1.5
-Device Fault Manager 2.0.7
-Internetwork Performance Monitor 2.6.0
-No ACS integration
02-12-2009 10:44 AM
The job may be in a state which does not allow for deletion. If you pdshow shows a 2432 daemon, try running:
pdterm 2432
Then see if the job can be deleted. If not, open a TAC service request, and they can walk you through removing the job from the database.
02-16-2009 07:51 AM
Thank you for your guidance. A TAC case has been opened as suggested.
