Yudong Wu Thu, 02/12/2009 - 11:29
  • Gold, 750 points or more
2100.0000.0000
ffff.ffff.fff8 should be the mask.
shivlu jain Sun, 02/15/2009 - 09:45
  • Silver, 250 points or more
can you elaborate or ptovide some doc how you calculated the mask.
regards
shivlu jain
Istvan_Rabai Sun, 02/15/2009 - 11:00
Hi Kevin,
I believe the access list should have a wildcard mask:
0000.0000.0007
Cheers:
Istvan
Yudong Wu Sun, 02/15/2009 - 15:03
You are right. Thanks for pointing this out. It should use wildcard mask. "1" means don't care and "0" means match exactly.
Explanation to shivlu:
So if we want to match 2100.0000.0000 to 2100.0000.0007, transfer the last Hex number 0 to 7 into binary format, 0000,0001,0010,0011,0100,0101,0110,0111. Therefore, we don't need to care last 3 bits. The mask should be 0111 = 7.
2100.0000.0000 mask 0000.0000.0007 should match all 8 mac addresses.
