latency with transparent vs routed firewall modes
Answered Question
Feb 12th, 2009
  • Bronze, 100 points or more
Hi there,
I've never used transparent firewalling and I'm wondering if there are any differences in the latency introduced by a firewall in routed mode vs transparent mode. Does anyone know if it's even an issue? Traffic loads will be around 100-200Mbps.
--Brandon
Correct Answer by cdusio about 8 years 4 months ago
There should be no difference. they both process ACL's but the transparent FW doesn't support NAT. Might see a slight difference if you are and then aren't doing NAT but I seriously doubt it.
Overall Rating: 5 (1 ratings)
Correct Answer
cdusio Fri, 02/13/2009 - 07:03
