anyconnect or clientless SSL vpn
Feb 12th, 2009
I need to access non-web based application through VPN. Can anyconnect support through ASA OR I have to use clientless SSL VPN connection. Basically I have to migrate users from vpn client to either anyconnect or clientless SSL.
Syed Iftekhar Ahmed Wed, 02/18/2009 - 16:50
For "non-web based apps" & "Experience similar to IPsec client" you should go with Anyconnect.Clientless SSL gives you access to a limited number of apps.
Syed Iftekhar Ahmed
mazheralam Thu, 02/19/2009 - 06:16
I tried it, it only supporting web based application. Does it needs to port forwarding for other applications?
