VIC2-2FXS in 1760 not showing...
snickered
I have purchased a VIC2-2FXS for my 1760 router. I have tried to install it in each of the slots (both VIC only and both WIC/VIC slots) but can't seem to configure it properly. http://www.cisco.com/en/US/docs/routers/access/1700/software/feature/guide/VIC_Cfg.html tells me to refer to refer to http://www.cisco.com/en/US/docs/routers/access/1700/1751/software/configuration/guide/Config.html#wp1028982. I try to enter 'voice-port 0/0' and I can't. I have tried several combinations of slot/port and nothing. Also, when I do a 'show run' I don't see the interface listed anywhere. When I do 'show inventory' it is listed as:
NAME: "WIC/VIC 0", DESCR: "2nd generation two port FXS voice interface daughtercard"
PID: VIC2-2FXS= , VID: V , SN: FOC100517P3
I can't seem to get the first step right. Can someone tell me where I'm going wrong here? TIA.
Adrian Saavedra
Level 7
Level 7
Please verify with show diag if you have PVDMs installed in your router.
If not, that is the reason.
Best regards,
- Adrián.
Adrian Saavedra
Level 7
Level 7
Best regards,
- Adrián.
Right after I posted this it occurred to me that I wouldn't be able to do anything with this FXS card with no PVDM. I have that on the way so I'll just have to be patient. Thanks for your reply.
Do a 'show diag | i PVDM'.
My guess is nothing shows up. You'll need one of the PVDM-256K DSPs for the 1760 in order to configure the dial peer.
You can check the DSP calculator for more details.
-nick
