Port down
branfarm1 Thu, 02/12/2009 - 14:59
  • Bronze, 100 points or more
Are both ends of the trunk configured with the same trunking encapsulation?
mfarrenkopf Fri, 02/13/2009 - 09:21
Sounds like you've got a layer 1 issue. Even if the trunk is not working, you should still be getting a physical connection. Is this fiber or copper? If it's fiber, try swapping the fiber ends. If copper, try replacing the cable.
Is it a brand new port that you're just bringing up or has it been up for some time and is being reconfigured? If it's new, you may have bad hardware.
The port is configured trunk. Is the other end trunk or access? Make sure the other end is trunk or some kind of dynamic settings (desirable or auto). Access won't make the trunk.
Check the logs. If there's a problem with the trunk, likely there will be error messages.
mfarrenkopf Fri, 02/13/2009 - 10:58
Is the port on the Procurve turned on? How about the encapsulation? It's dot1q?
It really sounds like a layer 1 issue because even if the trunk doesn't get negotiated, you should still see a physical link come up. It just won't pass traffic.
Mohamad Qayoom Fri, 02/13/2009 - 11:54
Do you have this port in a channel-group?
If so, you might want to see if the channel group is not shut down.
Mohamad Qayoom Fri, 02/13/2009 - 13:30
Can you please paste your ports' configurations?
Over the weekend, I tried using a 2950 but with the same results. Here are the port configs for both the 4006 and the 2950. Also, the 2950 is fiber connected to a 1000 speed media converter which is plugged into port 21 of the 4006.
4006:
interface GigabitEthernet2/21
description Procurve
switchport access vlan dynamic
switchport mode trunk
speed 1000
duplex full
no snmp trap link-status
spanning-tree portfas
2950:
interface GigabitEthernet0/1
switchport nonegotiate
mls qos trust cos
macro description cisco-switch
spanning-tree link-type point-to-point
mfarrenkopf Mon, 02/16/2009 - 08:16
Have you tried swapping the fiber ends? Using a different fiber patch cable? Do you have a different GBIC you can use?
Are there any errors in the log?
I'm presuming the speed/duplex are the same on the 2950. They should be as 1000/full is the default for gigabit. Why the "spanning-tree link-type point-to-point" if both ends are full duplex? That's implied with a full-duplex connection.
The "switchport access vlan dynamic" makes me nervous, although I can't find a reason why that should be causing your problem since you've declared the ports to be trunk.
Can you include the output of "show int GigabitEthernet0/1" from each switch?
Roberto Salazar Mon, 02/16/2009 - 12:05
  • Gold, 750 points or more
post both output from 4006:
show int gig 2/21
show int gig 2/21 switchport
show cdp neigh int gig 2/21
I finally got it figured out. It was a speed issue. As a test, I plugged a pc with a gig nic into the port. It came up saying 100.
I set the switch speed and duplex to auto. After that, I got connectivity with the 2950.
I'm starting to think that Procurve may be bad. We tried to plug a PoE injector into that was connected to an 802.11n AP but it would only work if we set the port on the Procurve to 100.
Thanks for the help eveyone.
