trouble with ACL
dflores83
I have a doubt with some access list, I try this command in the interface outside but the interface didn't take the instruction.
access-list(access-list-name) extended deny tcp host 192.84.255.51 host(hostname) eq smtp
access-list(access-list-name) extended deny tcp host 192.84.255.51 host (hostname) eq https
I think that the two access-list don't working and the default access-list (deny any-any)
is the unique list good
Someone have any Idea?
thanks
Tshi M
Level 5
Level 5
I am a bit confused. How did you apply the ACL to the outside interface?
access-group name_of_acl in interface outside
rgds,
yeah, I apply the same access-group
OK. So what is working and not working? You are not able to block those hosts from access smtp and https? Do you have other lines in your config? what is your log showing?
