WLC Code Upgrade
Feb 12th, 2009
We just got a WLC 4002 with software version. I have followed a procedure to upgrade and I know I need to follow this path>4.1->>5.2
However, I have tried to transfer the 4.1.185 on my controller and I get a
TFTP Failure while storing in flash!
Has anybody experience this?? any adive?
Leo Laohoo Thu, 02/12/2009 - 18:41
1. You could be either using a TFTP server that could not support file transfers greater than 32 MB (if this is the case, go to http://tftpd32.jounin.net/tftpd32_download.html and use TFTP32).
2. Looks like you were upgrading the firmware without upgrading the Bootloader (ER).
Using the same process as the firmware, download and install Bootloader (in the follwoing order)
AIR-WLC4400-K9-4-1-171-0-ER.aes before you install firmware 4.1.185. Then
AIR-WLC4400-K9-4-2-61-0-ER.aes and install AIR-WLC4400-K9-4-2-61-0.aes. Finally, install Bootloader
AIR-WLC4400-K9-5-2-157-0-ER.aes before you install the final 5.x firmware you want.
Sorry, it's a very long process but it's the only way.
Have you seen this documentation:
Wireless LAN Controller (WLC) Software Upgrade
