enabling outgoing caller ID - restriction
Feb 12th, 2009
I m using call manager 4.2.1 and trying to enabling outgoing caller ID for some of the route pattern.
Since some of the route pattern needs to show caller ID while some needs to show as "Private". I have set up the following:
Calling Line ID Presentation : restricted
Calling Name Presentation: restricted
Route group setting:
Use Calling Party's External Phone Number Mask : DEFAULT
Gateway ( outbound call) :
Calling Party Presentation: default
My problem is, its still showing the caller ID even i have restricted it in the route pattern level.
Any idea?
kind regards
Rachel
paolo bevilacqua Thu, 02/19/2009 - 10:14
  • Hall of Fame,
    Founding Member
Do you have ISDN ? If so, take a debug isdn q931 with term mon and post it here.
Ayodeji Okanlawon Thu, 02/19/2009 - 11:38
  • Cisco Designated VIP,
    2017 IP Telephony
These are the settings I have used in the past for this and it did work.
1.calling party presentation...restricted
2.calling party IE number type unknown...unknown
The rest were left at default values. This is set on the gateway in callmanager.
