802.1x, switch 3550, radius server
Answered Question
Feb 12th, 2009
  • Bronze, 100 points or more
Hi every body!
If i want to configure switch 3550 to use 802.1x with radius server. Are the following steps are correct?
switch(config)# aaa new-model
switch(config)# radius-server host 10.10.10.10 key cisco
switch(config)# aaa authetication dot1x default group radius.
switch(config)#aaa authentication network default group radius
switch(config)# dot1x system-auth-control
switch(config) int f0/1
switch(config-if) dot1x port-control auto
Do we need the command"aaa authentication network default group radius" or not?
thanks a lot!
Correct Answer by Jon Marshall about 8 years 2 months ago
Sarah
"Do we need the command"aaa authentication network default group radius" or not?"
No you don't need it, it is optional if all your are doing is configuring 802.1x. See this link for more details -
http://www.cisco.com/en/US/docs/switches/lan/catalyst3550/software/release/12.2_44_se/configuration/guide/sw8021x.html#wp1155289
Jon
Overall Rating: 5 (1 ratings)
Correct Answer
Jon Marshall Thu, 02/12/2009 - 20:11
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Sarah
Jon
