L3 Sub Interfacing on a HWIC-4ESW
Answered Question
Feb 12th, 2009
Is it possible to create multiple L3 subinterfaces on a port on a HWIC-4ESW? The HWIC is in an 1841 running IOS 12.4.
Correct Answer by paolo bevilacqua about 8 years 3 months ago
You're welcome, please rate useful posts with the scrollbox below.
Overall Rating: 4 (1 ratings)
Leo Laohoo Thu, 02/12/2009 - 20:44
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
I don't think this is possible. Cisco EtherSwitch HWICs are 10/100BASE-T Layer 2 Ethernet switches with Layer 3 routing capability. (Layer 3 routing is forwarded to the host and is not actually performed at the switch.) Traffic between different VLANs on a switch is routed through the router platform.
http://www.cisco.com/en/US/docs/ios/lanswitch/configuration/guide/lsw_hwic_ethsw_ic_ps6350_TSD_Products_Configuration_Guide_Chapter.html#wp1113532
Leo Laohoo Thu, 02/12/2009 - 20:52
  • Hall of Fame,
    2017 LAN, Wireless
You can create VLAN's and Trunks but this is a simple Layer 2 Switch (like the 29X0 Smartport switches).
http://www.cisco.com/en/US/docs/ios/lanswitch/configuration/guide/lsw_hwic_ethsw_ic_ps6350_TSD_Products_Configuration_Guide_Chapter.html#wp1046684
dnorthrup Thu, 02/12/2009 - 20:57
Thanks. I found the same document but could find no reference to L3 here or in any other resource. Obviously I was hoping to find some method to do this.
Leo Laohoo Thu, 02/12/2009 - 21:15
  • Hall of Fame,
    2017 LAN, Wireless
The router, in your case the 1841, can do the L3 for you.
Richard Burts Fri, 02/13/2009 - 08:35
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Dwight
Perhaps I am not clear about what you are trying to do on the Etherswitch in the 1841. But it seems to me that you can get what I think you are trying to do by doing this:
- configure several VLANs in the switch.
- assign switch ports to different VLANs.
-configure VLAN interfaces, assign IP addresses.
You can not do multiple layer 3 subinterfaces in the Etherswitch but multiple VLAN interfaces gets you essentially the same result.
Rick
dnorthrup Fri, 02/13/2009 - 09:18
Hi Rick. Thanks for getting back to me. When I picked the project up the 4-port switch card had already been purchased with the intent to carry multiple subnets off of one port. This configuration is still needed so the plan is to swap out for a HWIC-1FE card.
paolo bevilacqua Fri, 02/13/2009 - 09:53
  • Hall of Fame,
    Founding Member
You should be able to do that with the HWIC-4ESW. For example:
interface fa x/y/z
switchport mode trunk
interface vlan10
ip address z.z.z.z
interface vlan 15
ip address k.k.k.k
This way you will have the two subnets 802.1q tagged as 10 and 15 out the referenced port.
Or, same VLANs as above but:
interface x/y/0
switchport mode access
switchport access vlan 10
interface x/y/1
switchport access vlan 15
You will have untagged packets for the two subnets, separately, on the 1st and 2nd port of the module.
Correct Answer
paolo bevilacqua Fri, 02/13/2009 - 10:59
  • Hall of Fame,
    Founding Member
