Can reset aironet 1310 password and keep Previous setting
Feb 12th, 2009
HI...I got 4 aironet 1310,but i don't have password into Eanble mode!!
I follow this document "Password Recovery Procedure for the Cisco Aironet Equipment.pdf" to recovery password.
It succeed reset password to default,but it also reset Previous setting to defalut.
Can I reset aironet 1310 password and keep Previous setting? Plz!!
I really need help for this,thanks.
p.s My english not good
Leo Laohoo Thu, 02/12/2009 - 20:53
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Username: Cisco
Password: Cisco
Enable Password: Cisco
Try this and I hope it works.
Chiayu.cheng Thu, 02/12/2009 - 23:51
Thank you for reply
but can't help to me.
I seeking a way that can reset password to default and can keep Previous setting
thank you
richardbergen Thu, 08/30/2012 - 07:36
years too late, but this might be helpful for someone else:
- Reboot the aironet
- As soon as you see the following, hit the ESC key twice to interrupt the booting process
flashfs[0]: 147 files, 7 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 7741440
flashfs[0]: Bytes used: 5544960
flashfs[0]: Bytes available: 2196480
flashfs[0]: flashfs fsck took 32 seconds.
Base ethernet MAC Address: 70:81:05:3a:75:0a
Initializing ethernet port 0...
Reset ethernet port 0...
Reset done!
ethernet link up, 100 mbps, full-duplex
Ethernet port 0 initialized: link is up
Loading "flash:/c1310-k9w7-mx.124-25d.JA/c1310-k9w7-mx.124-25d.JA"...############
- If you would like to view the old config, type the following command from the bridge: prompt
more flash:config.txt
- for password recovery, delete or rename the env_vars and config.txt files in flash:
bridge: dir flash:
Directory of flash:/
2 -rwx 5 private-config
3 -rwx 277 env_vars
5 drwx 256 c1310-k9w7-mx.124-25d.JA
4 -rwx 1048 private-multiple-fs
155 -rwx 1487 config.txt
- when you are finished, boot the AP by typing in boot and hitting enter
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
