Cisco 2800 Internet routing
Answered Question
Feb 12th, 2009
I have a very typical issue
I want to undersdtand if a Cisco 2821 with 1 Gb DRAM can absorb the whole Internet routing table ,though i understand it wud'nt be an optimum solution and any supporting documents if available
Correct Answer by Giuseppe Larosa about 8 years 2 months ago
Hello Sudhir,
I haven't a link for this.
Probably an official Cisco answer wouldn't recommend to use a C2821 for handling a full BGP table.
If I remember correctly someone has reported to doing this here in the forums.
The only doubts are about the cpu average usage caused by the BGP process: memory will be enough.
Some tuning of BGP scanner frequency can be needed in order to reduce CPU usage
And of course only if you are receiving a single BGP full internet table and no more.
Hope to help
Giuseppe
Overall Rating: 5 (1 ratings)
Giuseppe Larosa Thu, 02/12/2009 - 21:58
  • Hall of Fame,
    Founding Member
Hello Sudhir,
yes with 1GB RAM the c2821 can host a full BGP table of 270,000 routes and it is able to create a CEF table for all the prefixes.
What you cannot have is capability to forward traffic at GE speeds (full rate)
Hope to help
Giuseppe
Sudhir Menon Thu, 02/12/2009 - 23:58
Hi Giuseppe
Thanx for your reply do you have any supporting documents mentioning the same if not directly from Cisco
Correct Answer
Giuseppe Larosa Fri, 02/13/2009 - 09:14
  • Hall of Fame,
    Founding Member
Hello Sudhir,
Hope to help
Giuseppe
Sudhir Menon Fri, 02/13/2009 - 20:46
This has centianly helped me a lot thank you very much Giuseppe ,I was just hoping to find a document as i had a customer call on this
