Microsoft Dynamics AX Access through an ASA
Feb 12th, 2009
I permitted https, web and 1433 (SQL) access from the outside to the Enterprise Portal (EP). I can access the EP, but I cannot then get information from the Reports/Analysis box. The system works ok from the inside.
murphg Sun, 02/15/2009 - 17:58
Yes, but this box is being used as the Database box as well.
murphg Sun, 02/15/2009 - 18:04
I'm learning more about Microsoft Dynamics as I go through this process, but I feel that if the Dynamics set up had been completed correctly, I would only have to open the firewall for web/https access After that, the EP would then proxy everything else. I guess that my basic problem is that I don't know enough about Dynamics to tell the client that it hasn't been set up correctly.
