deactivate BGP neighbour through SNMP
Feb 12th, 2009
Preved!
I need to change admin status of neighbour through snmp. I have typed the next command:
C:\snmp\bin>snmpset -v 2c -c SetSNMP 192.168.132.2 1.3.6.1.2.1.15.3.1.3.2.2.2.2 i 2
(2.2.2.2 - ip address of my neighbour)
But have got the next error.
Error in packet.
Reason: notWritable (That object does not support modification)
Failed object: SNMPv2-SMI::mib-2.15.3.1.3.2.2.2.2
Have anybody any ideas how to change this oid?
Joe Clarke Thu, 02/12/2009 - 23:06
Cisco IOS does not implement any of the objects in the BGP4-MIB as read-write (only read-only).
However, if you want to bring a neighbor up which is shutdown using SNMP, you could upload a config snippet to the device which removes the shutdown command from the neighbor statement. To do this, follow the instructions in this tech tip:
http://www.cisco.com/en/US/tech/tk648/tk362/technologies_configuration_example09186a0080094aa6.shtml
alexandr.serebriakov Thu, 02/12/2009 - 23:18
Hi!
Thanks for fast answer.
But before I have found this OID in Cisco SNMP object navigator. It presents as read-write. :(
bgpPeerAdminStatus OBJECT-TYPE
SYNTAX INTEGER {
stop(1),
start(2)
MAX-ACCESS read-write
STATUS current
DESCRIPTION
Where is the error?
Joe Clarke Thu, 02/12/2009 - 23:31
The MIB defines the MAX-ACCESS as read-write. However, IOS only implements the object as read-only. This is allowed by the MIB specification. There is no error. You will not be able to set this object.
