CLUSTERING ONLY TWO 4510R SWITCHES
Feb 12th, 2009
Dear All ,
I have ony two 4510R switch,i want to put them in clusters now,also i have created one hsrp group in both switch already.Also i m attaching run config of both the switches.
Amit Kulshreshta
mchin345 Wed, 02/18/2009 - 08:57
  • Silver, 250 points or more
If you plan to use clustering, enter the cluster run global configuration command on each device, and enter the ip address interface configuration command on the cluster commander.
